Looking for a Spice model
Discussion in 'General Electronics Chat' started by R!f@@, Jul 13, 2016.
  1. R!f@@
    Thread Starter AAC Fanatic!
    Apr 2, 2009
    8,793
    771
    I am looking for a spice model for the part ACS723LLCTR-10AU-T.
    I cannot find it on Allegro site.
    Does it exist ?
    Is it easy to make one ?
  2. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Depends how accurate a model you want. The functional diagram in the datasheet would be a starting point, but is rather vague in some areas.
  3. R!f@@
    Apr 2, 2009
    8,793
    771
    I had run into a problem.
    China and ebay does not seem to have this part ACS723LLCTR-10AU-T.
    Does any one here got it for sale. I want around 5 pcs.
  4. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Is there no suitable alternative to that particular part?
  5. Techno Tronix
    Member
    Jan 10, 2015
    140
    10
  6. R!f@@
    Apr 2, 2009
    8,793
    771
    Since I cannot get it I had to rethink my design and I think I have a working solution.
    But it does require a bit more coding for the PIC than with just two ADC's for Voltage and current. All I had to sacrifice was just one more ADC and use additional OP340 opamp instead of the current sensor, which I think is a much cheaper solution.
  7. eetech00
    Jun 8, 2013
    685
    118
    Well, if you change your mind and decide to use ACS723...
  8. R!f@@
    Apr 2, 2009
    8,793
    771
    I might still like to use it in future. So I am interested.
    Ur image shows bi-directional. What I need is uni-directional one
    ACS723LLCTR-10AU-T.
    Do you have it ? The spice. I need to use it for NI Multisim
  9. eetech00
    Jun 8, 2013
    685
    118
    Hi
    Yes I have it, but only for LTspice. See post #7.
  10. R!f@@
    Apr 2, 2009
    8,793
    771
    I think it is possible to make a multisim model using spice model
  11. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Is it a home-brew model or an 'official' one from Allegro or elsewhere?
  12. eetech00
    Jun 8, 2013
    685
    118
    I checked with Allegro and they didn't have one so I modeled it myself.
    I checked the model against the part. The output waveform and sensitivity is correct for both AU and AB devices. I didn't model the BW select pin, magnetic field coupling, or temperature characteristics. Its a behavioral model created using data sheets and bench tests.
  13. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Would you care to share the model files? Other members here may find them useful.
  14. eetech00
    Jun 8, 2013
    685
    118
    Sure.
    The attached zip file includes a test circuit sim.
    I used a UniversalOpamp2 for the level shifter on the sim. but for the bench test, I used an LM358.
    Have fun...
  15. Alec_t
    Sep 17, 2013
    5,980
    1,138
    Thanks.
