Looking for a rotary position sensor
Santhakumar
Joined Mar 17, 2015
33
Hi ,
I have been looking for rotary position sensing device (might be angle measuring Device)
I Don't want to use any magnet (Hall effect sensors)..so help me with Inductive or capacitive angle measuring device if available.
-Santhakumar.
GopherT
Joined Nov 23, 2012
8,009
Hi ,
-Santhakumar.
A potentiometer with a linear-taper makes a great and simple angle measuring device. Simply connect the two static legs to positive and ground reference - then measure the wiper pin to get your angle as the pot is turned. The higher the pot quality, the better performance is possible.
hp1729
Joined Nov 23, 2015
2,304
Hi ,
-Santhakumar.
Through how many degrees of rotation and with what precision?
jpanhalt
Joined Jan 18, 2008
11,087
At least 180 degrees.I want it to be contactless. Precision can be 5 degrees
The capacitative sensors are contactless and well more accurate than 5°. Since you mention "angle measuring device" a simple accelerometer will give angles relative to Earth well within your 5° criterion. It is a simple calculation to find the angle between two legs, given that data (assuming 2 dimension).
MaxHeadRoom
Joined Jul 18, 2013
28,699
One problem with incremental encoders is they need to be referenced at power on, the absolute are typically 12bit with up to 16bit available.
The CUI John mentions have absolute as well as incremental.
This is a simple BCD etc.
