Hmm ! that's sound quite wonderful.If you are making an array of LED modules why not use ole reliable serial data?
I think you know what I had in mind.
If it is not too much to ask, can you explain me how to trigger using one wire, please
There's very little difference in size between the 6 pin and 8 pin PIC once you use the SMD versions....
The project is a secret. I have strict space limitations. ...
You need to say if the I2C comms is master or slave. I'm guessing you have an I2C sensor? So the PIC is the master?...
How much space is required for coding I2C in software and give a fade out delay of 1 to 2 seconds?
Well it's kinda the only reason you want to add a PIC to simplify things.Hmm ! that's sound quite wonderful.
Well because it's so secret we really don't know your size constraints. To me it's hard to imagine a situation where a SOT-6 will fit and a SO-8 won't... There's only a couple of mm difference involved. But it's your baby.There are multiple device. And using one pin saves a lot I must say.
The SOT package is smaller than a SMD PIC, right ? This saves a lotta space too.
Sounds like the master just needs to send a device address, and then if a device hears its own address it does its flashy task....
Tx will be needed at the master PIC which controls the SOT PIC's and the master does not need to know what is triggering or not, it just needs to send out address telling to trigger which and when.
"At once" has different meanings in the computer world....
The point where triggering both is some what bad. Cause I might need to trigger two devices at once.
