Looking for a PCB power jack
Discussion in 'The Projects Forum' started by wayneh, Dec 2, 2014.
  1. wayneh
    Thread Starter Expert
    Sep 9, 2010
    12,379
    3,234
    I need something like this.
    I'm having trouble finding one that will definitely fit a protoboard with 0.1" hole spacing, like these. It seems most jacks have leads that are too fat to fit in the holes, and/or don't have the pins on 0.1" centers.
  2. ISB123
    May 21, 2014
    1,240
    531
    You could try sanding them down or glue them with hot glue,bend the legs back and solder wire on them and pull the wire through the holes.
    #12 likes this.
  3. wayneh
    Sep 9, 2010
    12,379
    3,234
    Haha, love it. Don't know why I didn't think of that.
    I guess I was hoping someone here knows of the perfect part.
  4. MrChips
    Oct 2, 2009
    12,625
    3,451
    My guess is the part you are requesting does not exist, not in 0.1" pitch.
  5. KJ6EAD
    Apr 30, 2011
    1,426
    363
  6. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
    Co-incidentally I fitted one today on strip board, it is smaller than I usually use however, I generally drill the board to take the 6mm recepticle size, the .1" spacing version takes a 4mm dia power plug end. The holes have to be slightly enlarged to enter the strip board.
    I got these from Digikey.
    Max.
  7. djsfantasi
    Apr 11, 2010
    2,902
    877
    Can you share a part # or a link?
  8. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
    djsfantasi likes this.
  9. wayneh
    Sep 9, 2010
    12,379
    3,234
    This project is not going in a box, and that's why I was looking for PCB mounting, but now I'm leaning towards putting a little patch panel next to the mounted PCB. It may give me more, simpler options.
  10. #12
    Nov 30, 2010
    16,671
    7,318
    I use the drill method because that's what is convenient in my tools. I can put any size hole anywhere and compensate on the copper side, but this idea might work even better!
  11. wayneh
    Sep 9, 2010
    12,379
    3,234
    The protoboard has no copper side, so widening the plated through hole risks removing the plating entirely. That might be OK. If hole size was the only hurdle, I might drill. The 0.1" pitch is another problem. I can bend, glue and wire if I have to. Still weighing options.
  12. MaxHeadRoom
    Jul 18, 2013
    10,836
    2,510
    The ones I linked to only require a small enlargement at .1" spacing.
    I have always found strip board the most flexible for prototypes or one-off's, I get them here http://www.futurlec.com/ProtoBoards.shtml
    Max.
