Looking for a DPDT slide switch....
Discussion in 'Marketplace' started by DerStrom8, Jul 25, 2012.
Thread Status:
Not open for further replies.
  1. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Hi guys. I've been searching for a while now and couldn't seem to find the switch I'm looking for.
    I need a small DPDT slide-switch with a A68-A31 package (according to Eagle). I've attached a picture with dimensions of what I'm looking for. Does anyone know where I can get one of these, whether you have some to sell, or just have a link to an online store that carries them? I would very much appreciate any help. Thanks guys!
  2. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    I'm also looking for some of these connectors, but since I don't know what they're called, it's making things difficult. Hopefully you guys can help :D
    I'll need two of the 2-pin connectors and one of the 3-pin connectors. Thoughts? Ideas?
    Thanks!
  3. praondevou
    Jul 9, 2011
    2,936
    489
  4. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Thanks a lot for the suggestion. So far I'm finding tons of switches with .1" spacing between the rows, but none with .2" spacing....
  5. praondevou
    Jul 9, 2011
    2,936
    489
  6. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Woah, $3.41 for a tiny switch? :eek:
    I'll have to think about that one. Thanks for the link :)
  7. praondevou
    Jul 9, 2011
    2,936
    489
    Really hard to find. Might be easier create your own component if you don't find existing switches with the correct pin pitch in your library.
  8. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Building my own switch would be kind of difficult, I think :D I'm assembling this board and am in need of a real-life switch for it ;)
    I think I might have found someone who can source the switches, but that leaves me with the connectors. Does anyone recognize the footprint of the connectors in the second post? I don't know what they're called. All I know is that they're in the "con-amp-mt" Eagle library, under the name L02P (for the 2-pin ones), and L03P (for the 3-pin ones). I'm looking for a supplier for these connectors.
    I very much appreciate your help! :)
    Best wishes
  9. praondevou
    Jul 9, 2011
    2,936
    489
    LOL. I meant creating the component layout of a real-life switch in your EAGLE library... :rolleyes:
    DerStrom8 likes this.
  10. praondevou
    Jul 9, 2011
    2,936
    489
    What's the pitch?
  11. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Hahaha, oops :D
    Unfortunately, the boards have already been made. I should have sourced the components before ordering the boards. I'll definitely be more careful about that next time :rolleyes:
  12. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    0.1 inch.
    _______________________________
  13. BSomer
    Member
    Dec 28, 2011
    433
    106
    Here is a switch that conforms to your dimensions. As for the connector, look for a "shrouded male header".
  14. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    The 600 series M2 footprint (and likely others) has your spacing as well. Probably much less $$ than NKK. Mouser has them.
    http://www.e-switch.com/Portals/0/Series_Pdf/600.pdf
    It looks like an AMP MTA-100 or CST-100 II series would do the job. At least, these are common series that you can actually buy. The catalog link from this page has drawings and variants. Mouser has the CST-100 series in stock.
    http://www.te.com/catalog/bin/TE.Co...86009,97841,72701,50818,52709,98284,98331&N=1
    I've made that mistake, too. Over time, I have built my own library of components as I source them, some new, some updated from Eagle's libs but always with a real manufacturer's and Mouser/Digikey/Newark/Allied etc part number. Just copy/paste onto the order form as I lay out the board.
  15. Wendy
    Mar 24, 2008
    20,772
    2,540
    The motor connectors, do you need connectors, or can you use these?
    [​IMG] [​IMG]
    BG Micro - Stackable blocks
  16. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    Wow, $4.55 for a switch? :eek:
    Thanks very much for the suggestions. Especially regarding the connector. Now I have a place to start :)
    These links were very helpful, thank you :) I appreciate the help!
    I could probably use those, but I would prefer the regular connectors. I could use these as a last resort, if I absolutely had to.
  17. shortbus
    Sep 30, 2009
    4,092
    1,673
  18. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    I wasn't quite sure what to look for, so I didn't bother. I'll check it out though :)
Thread Status:
