Looking for 11 pin panel socket and plug
Discussion in 'The Projects Forum' started by bowlingo, Feb 1, 2012.
  1. bowlingo
    Jun 29, 2011
    162
    Hi all,
    I am looking for a plug and socket of which is quite robust and easy to solder.
    I am looking to run 9 x 230V max 1A each pumps, common neutral and an earth
    Any ideas on a female panel socket and male plug so I can 1 x multicore lead from one unit to another and simply plug it in?
  2. BSomer
    Member
    Dec 28, 2011
    433
    106
    Go to one of the online distributors like Mouser or DigiKey and use their parametric search with the requirements you need i.e. pin count, current rating, voltage rating... That would be the easiest way to do it, other than asking someone else to do it for you. :)
  3. GetDeviceInfo
    Jun 7, 2009
    1,571
    230
