Lookie what I scored from schooll =D
Discussion in 'General Electronics Chat' started by Overclocked2300, Apr 26, 2005.
  1. Overclocked2300
    Thread Starter Senior Member
    Apr 24, 2005
    124
  2. Amplifier
    Oct 18, 2004
    5
    Yeah Mr. P finally got rid of those...
    What do you plan on doing with them?
  3. MICRO-HENRY 2000
    Apr 26, 2005
    Looks like a big pile of **** to me.
  4. Overclocked2300
    Apr 24, 2005
    124
    Who the hell are u..lol
    They arent a pile of ****..they have some prettuy good parts in them..a variac or 2..AS huge ass transformer and some TO3 Heatsinks..dials knobs..etc all that good stuff..
    Hopefully the transformer isnt an isolation transformer and its like a 38V transformer because the panel does have something to vary voltage...
    Forgot to mention there are some computer grade caps too..
    and oh to answer your question...I dunno ..parts just to have it... The transformer I could use..Its pretty big so it must be able to output alot of current. The heatsinks I can definatly use. I am going to build some type of high wattage amp and had TO3 transistors.
  5. mozikluv
    Jan 22, 2004
    1,437
    hi,
    looks like you're excited with your acquisition, anyway do you know how to test a shorted transformer. you can use the caps for experiments but not for long term use. remember used caps has a low reliability factor whether high or low grade. it's always best to use new caps for any project.
  6. Amplifier
    Oct 18, 2004
    5
    Mikey Gs brother's friend, a junior.
  7. Overclocked2300
    Apr 24, 2005
    124
    Ya use the the ohms setting on a multimeter. A teacher of mine gave me a vacuum tube meter, but I have a digital meter as well.
  8. mozikluv
    Jan 22, 2004
    1,437
    hi
    you can use the ohmmeter to check for continuity but not for shorted primary wire or secondarywire. even if you ready the resistance it still not give you the indication that it is shorted.
  9. Overclocked2300
    Apr 24, 2005
    124
    Then how do u check for shorts and opens?
  10. mozikluv
    Jan 22, 2004
    1,437
    hi
    ok, watch for it in the "transformer projects" it's good this thing came up, i hve it in mind to post it but never came up to do it. i'll have to draw the circuit, it's nothing complicated but surely helps.
  11. Overclocked2300
    Apr 24, 2005
    124
    if u dont mind..can I guess what it is? A simple circuit with a LED or a diode with a meter.
    IF the diode lights the the transformer has no opens..hmm but what about shorts..hmm..
  12. mozikluv
    Jan 22, 2004
    1,437
    hi overclock2300,
    check the transformer project topic, i have posted the circuit since i believe it would be more appropiate if i post it there.
