Look my led connection schematic
Discussion in 'The Projects Forum' started by Lightfire, Apr 14, 2011.
  1. Lightfire
    Oct 5, 2010
    690
    21
    Is it correct?
    I know, I mean I guess, it's not correct because of the polarity. but let's say the polarity is correct, is my led correct???
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,383
    The schematic is correct.
    Only all details are missing.
    What is the battery voltage?
    What is the voltage drop of each led?
    What current should be used for the leds?
    Bertus
  3. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Everything appears to be correct so far.
    The battery is drawn with the positive terminal towards the top of the schematic, which is the way it should be.
    The resistors will limit the current through each series LED string, which is how it should be.
    The LEDs are shown with the anodes on top and the cathodes towards the bottom, as they should be.
    Basically, all you need now is the battery voltage, the LED typical Vf (forward voltage) at a given current, and then calculate the resistors.
    It would also be good to include a fuse and a power switch.
