look at this circuit
Discussion in 'General Electronics Chat' started by Highlight, Jul 9, 2012.
  1. Highlight
    Nov 26, 2010
    28
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Transformers are bi-directional. Secondaries in parallel will not sum voltages, but they might sum currents depending on the phases.
    What actually did happen?
  3. #12
    Nov 30, 2010
    16,673
    7,320
    Have you checked the building for surge suppressors?
    and yes, the low impedance of the power line transformer is swallowing your energy.
    you need to insert an impedance in the AC-H before it goes into the line between "step-up" and "load".
  4. Highlight
    Nov 26, 2010
    28
    I put an o-scope at the load and just saw the 115VAC mains w/ no spike. When i removed the 115VAC at the secondary windings and switched the relay i did see a large spike. I think the 115vac at the secondary is killing the spike somehow.
  5. Highlight
    Nov 26, 2010
    28
    Would a .1uf capacitor be enough?..That would give me 26.5Kohms impedance at 60Hz.
  6. #12
    Nov 30, 2010
    16,673
    7,320
    I am seriously at a loss as to the magnitude of currents you are working with. (The first drawing can be interpreted in the milliohm range.) The size of the capacitor depends on the load. Will the load still operate with the current of the power line limited to a couple of milliamps? You (we) need some labels!
