Long Range Ultrasonic Sensor
Discussion in 'General Electronics Chat' started by HallMark, Sep 19, 2013.
  1. HallMark
    Apr 3, 2011
    89
    5
    Hello Friends,
    I am looking for Ultrasonic sensor which can be used to measure distance atleast 12-15 meter with good accuracy.
    Can anybody suggest me such sensor?
  2. strantor
    Oct 3, 2010
    4,302
    1,989
    I have never used this sensor, but I have used similar (smaller range) sensors from this manufacturer, and I rate their performance as "excellent."
    http://migatron.com/products/rps-3000/rps-3000.htm
    Now, before you go and buy that, look at the pretty pictures. This thing is suggested as a sensor to sense tank level, a pretty big target. Are you trying to sense tank level? or distance to a wall/other large target? or distance to a mosquito flying on the other side of a warehouse?
  3. mcgyvr
    Oct 15, 2009
    4,789
    975
    and define "good accuracy"
  4. HallMark
    Apr 3, 2011
    89
    5
    Thank you Buddy,
    Yes there is one tank and I want to measure it's level. It may contain some chemical or water.
  5. sirch2
    Jan 21, 2013
    1,008
    351
    I recently built an ultrasonic distance measuring unit that could do better than 13m from transmitter to receiver with an array of 7 standard cheap ultrasonic transducers. Upping the gain on the receive amplifier and taking a bit more care over tuning the transmitter resonant circuit may well get a lot further. Accuracy, when compensated for temperature, is around 10 to 20mm.
    Is it 15m to the fluid or 15m round trip - i.e. 7.5m above the low level?
  6. HallMark
    Apr 3, 2011
    89
    5
    It is 15m to the fluid. But round trip around 22m is also fine. Can you give me some more detail about the setup you have done?
  7. sirch2
    Jan 21, 2013
    1,008
    351
    I've been meaning to get the write-up on line for a while now so I will try to do that tonight. But in a nutshell the transmitter is 7 transducers (6 in a hexagon, 1 one in the centre) to form a basic beam-forming array. This is driven as a series LC circuit by a 40kHz square wave from an arduino.
    The reciever is a two stage op-amp based amplifier with a gain of about 20 per stage followed by a schmitt trigger to drive an interrupt on the arduino and record the time taken.
    One thing you could do is use a similar array on the receiver side to get more gain.
  8. HallMark
    Apr 3, 2011
    89
    5
    Which sensor you have used in this array?
  9. HallMark
    Apr 3, 2011
    89
    5
    Use of array will result into higher Beamwidth right?
  10. sirch2
    Jan 21, 2013
    1,008
    351
    I used sensors similar to this one (only I bought direct from china via ebay)
    http://www.mouser.com/catalog/specsheets/KT-400242.pdf
    And no, the effect of the array is to make the beam narrower. The datasheet above shows a 60° beamwidth at -6dB, I can't remember the exact figure but my array gave something under 10° IIRC. Google Beam Forming, it's more often used in radio antenna etc. but work with any waves. Basically there is constructive and destructive interference and if you get the spacing right you can get constructive interference down the bore-sight of the array.
    Like I said, I'll try to get some details posted tonight and link to it from here.
    HallMark likes this.
  11. HallMark
    Apr 3, 2011
    89
    5
    Thanks for the more information. Waiting for your post. :)
  12. sirch2
    Jan 21, 2013
    1,008
    351
    strantor likes this.
  13. THE_RB
    Feb 11, 2008
    5,435
    1,305
    You're not worried about the "chemical or water" in the tank and condensation etc destroying your ultrasonic transducers? The entire inside of that tank will be wet and dripping.
    Why not use an immersible capacitance sensor or even an external capacitance sensor on the tank (if the tank is non-metallic)?
  14. HallMark
    Apr 3, 2011
    89
    5
    Tank is metallic. And I am planning to make casing for sensor so Chemical or water is not going to effect it.
  15. THE_RB
    Feb 11, 2008
    5,435
    1,305
    How are you going to put the ultrasonic sensor in a sealed case? The diaphrams need to be uncovered, so the ends of the transducers need to be open.
    A metal tank does not rule out capacitive sensing, it might even make it easier. :)
  16. sirch2
    Jan 21, 2013
    1,008
    351
    THE_RB and HallMark like this.
  17. GopherT
    Nov 23, 2012
    6,309
    4,029
    These are fairly common in the chemical/oil/process industries. I don't know why one would build one rather than buy one. They have intrinsically safe versions for use with solvents. Corrosion resistant versions for use with acids. Web browser addressable versions for plug-and-play. Life is so easy today.
    http://www2.emersonprocess.com/en-u...tters/3100-series-ultrasonic/Pages/index.aspx
  18. HallMark
    Apr 3, 2011
    89
    5
    Readymade is too much expensive and I want to use for personal use so looking for some cheaper solution. :)
  19. HallMark
    Apr 3, 2011
    89
    5
  20. THE_RB
    Feb 11, 2008
    5,435
    1,305
    Exactly, I thought you had already decided to build an array out of 7 cheap sensors as was previously discussed. THAT would be hard to seal airtight.
