I need references/schematics on long-range infrared transmitter and receiver
Im building a bot that supposed to find and approach a stationary beacon up to at least 5 meters away, (the minimum required is 5 meters, exceeding that is fine)I have decided to use IR for the beacon since sound based and RF based proved difficult due to certain traits that would prove a hindrance to the positional tracking
The bot also has a an IR collision sensors like the ones shown here http://www.e-gizmo.com/KIT/Collision.HTM
so I have to make sure that the beacon's signal does not interfere with the obstacle detector
Thanks.
Thanks.
