Long range forecast
Discussion in 'Embedded Systems and Microcontrollers' started by rougie, Sep 3, 2008.
  1. rougie
    Thread Starter Active Member
    Dec 11, 2006
    410
    I am a Microchip MCU user and using CCS's compiler to create, debug and compile C code for Microchips micro-controller units.
    I am looking to get the long range forecast informations from a weather station's website or a local airports website via my MCU. For example, I would need to know today's weather and the next 3 to 5 days weather. I must find this information in terms of data such as the temperature, humidity, winds etc... respective to a date.
    I know that CCS (CCSINFO.com) has a kit that shows you how to build an internet connection with a microchip micro-controller and I am debating on weather I should buy it. I have never done this and I have some preliminary questions about how I am going to do this.
    1) Even if my MCU is able to connect to another website showing the long range forecats, how would I be able to download the data mentioned above?
    2) Is this at all possible to do with a Microchip controller?
    All informations related to this post is greatly appreciated!
    Regards
    Robert
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You might check this link to see if you can use any of these formats -http://www.nws.noaa.gov/tg/modfiles.html.
  3. rougie
    Dec 11, 2006
    410
    Why has my post been moved?
    RR
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You are going to use a microcontroller and this section will have more people looking in with appropriate experience than in other forums.
