The attached circuit is a run-on timer for a bathroom fan. It is mains powered and uses an LM311 comparator with a RC on the inverting input and an adjustable R divider on the non-inverting input to set an on timer for about 10 minutes after the fan switch is operated and then turned off. A 2n7000 FET is gated by the comparator output and drives a solid state mains relay. The circuit works, but switching off is somewhat slow, taking about 5 seconds to drive from full on to full off. I have added positive feed back (82R and 1k2) around the LM311, and 1uF across the inputs (recommendations from the datasheet), but it doesn't seem to help (note that the 1uF is not shown on the schematic).
Can anyone suggest why the output switching is slow and any ideas to correct it?
Thank you for any thoughts.
