It's nothing special, really. But it should work.I'm going to prototype using Wookie's driver to see if it works.
Depends upon the differential between Vcc/Vdd and GND. It's a simple "pick your poison" type thing.It should have a 1ma current out the collector as set by the emitter resistor.
If you have a current draw problem with the circuit I drew, the problem is with the components, not the circuit.Assuming Q1 really sucked and had a beta of 10 it would still only draw .1ma from the base, and 1ma should turn Q2 on pretty well.
Are you running out of breadboards? This design isn't special enough to solder it down, unless it's going to be implemented somewhere.My current plan is to build the first 2 designs using TLC555s, then use my stock of 7555 for the rest of the experiments.
Why didn't you pick up a couple of Radio Shack PNP/NPN assortments, just to be sure you were working with "off the shelf" RS stuff?I bought a 15 pack of PN2222 and another of 2N3904 (I believe that was the P/N) to stick with the Radio Shack parts line.
What's a "tandilidium" ?The 1µF 250V cap was huge, so I'll try the tandilidium cap for the prototype too.
