Logisim - D flip flop
Discussion in 'The Projects Forum' started by gs99, Jan 31, 2013.
  1. gs99
    Jan 31, 2013
    I made a circuit in Logisim that reflects the D Flip Flop on this page:
    http://www.play-hookey.com/digital/sequential/d_nand_flip-flop.html
    The circuit works as the play-hookey diagram.
    When CLK goes from 1 to 0, whatever is in D goes to Q.
    But if I start a new circuit and use the first D Flip Flop,
    the ouput lines are red.
    Question 1.
    Why are the lines red?
    Question 2. Is there an easy way to reset Simulation?
    I've been doing this:
    D1
    CLK1
    D0
    CLK0
    When I do Ctl R, some lines go red.
  2. Macgiver007
    Jan 17, 2011
    Using an Inverter on one of your "Q" output will create a "0" when you reset. Also, a NO switch for your clock input will assure that the clock will not activate to a "1" when reset.
  3. Macgiver007
    Jan 17, 2011
    The lines output are red because the D Flip Flop is being clocked after reset.
