I need 12 volt logic input and 12 volt output. If I need to change each logic input and the power input/output it would seem like it would get pretty expensive unless there is some cheap component I am unaware of.You could just take a 5V gate and boost the voltage to 12V.
Nanovate gave you the answer. It's also called the CD4000 series.I need 12 volt logic input and 12 volt output. If I need to change each logic input and the power input/output it would seem like it would get pretty expensive unless there is some cheap component I am unaware of.
I looked at texas instuments and was unable to find any. I will continue searching.
Thread starter | Similar threads | Forum | Replies | Date |
L | Propagation delays in control lines and potential bus contention | Digital Design | 4 | |
Y | feedback correction logic mechanism | IC Design | 3 | |
B | Logic Switch Debounce solutions | Datasheets, Manuals & Parts Identification | 11 | |
M | How to use logic analyzer | Microcontrollers | 7 | |
P | Shift register/serial logic voltages | Homework Help | 6 |
by Aaron Carman
by Aaron Carman
by Aaron Carman
by Jake Hertz
