Logic Optocoupler for 8 Channel - Possible?
Discussion in 'Homework Help' started by Mizs Faa, Dec 1, 2015.
  1. Mizs Faa
    Nov 25, 2015
    11
    Hi, im doing my current project which is i have to connect with solenoid valve to arduino using N-channel Mosfet.
    The problem is i need to use LOGIC OPTOCOUPLER for my circuit connection as precaution.
    So im gonna use 8 solenoid valve which is IF im using single channel of optocoupler, i need to use 8 of optocoupler in my circuit.
    The problem was the 8 channel of logic optocouple is possible? because im searching for it through website unfortunately i didnt found. Im only found 2channel of optocoupler (Logic).
    http://docs-asia.electrocomponents.com/webdocs/0779/0900766b8077970f.pdf
    That nice if you can share some link of 8 channel LOGIC optocoupler or maybe 4channel of LOGIC optocoupler.
    Best Regards,
    Faa
  2. ericgibbs
    Jan 29, 2010
    2,598
    394
    hi,
    There are quad channel opto's
    Ref this PDF.
    E
  3. Mizs Faa
    Nov 25, 2015
    11
    Thanks for that.. I have found 4 channel but that mounted. Any idea how to use it on breadboard?
  4. Mizs Faa
    Nov 25, 2015
    11
    Sorry, Is that a logic optocoupler?
