logic level mosfet switching
Discussion in 'Analog & Mixed-Signal Design' started by Amit Ika, Aug 31, 2016.
  1. Amit Ika
    Jul 4, 2016
    10
    Hey guys,
    I'm somewhat new to circuits and im confused right now. I have a logic level mosfet. Here's the data sheet:
    https://www.fairchildsemi.com/datasheets/IR/IRL640A.pdf
    Anyways, I am trying to switch 12 volts with this. I am giving the gate a 5 volt signal via an Arduino (and this is for sure. I've measured it many times), yet I am only able to get a source-drain voltage of about 4 volts. What am I doing wrong? How can I increase it to 12 volts without increasing the gate voltage? I am open to using another transistor but I've used a few others and its the same outcome. Does anybody know what the problem could be? Thanks.
  2. jpanhalt
    Jan 18, 2008
    5,699
    909
    That is an N-channel mosfet. Are you trying to use it to source or sink current? Please post your circuit.
    John
  3. crutschow
    Mar 14, 2008
    13,505
    3,376
    An N-MOSFET can only switch between the load and ground.
    If you want to switch a grounded load then you need a P-MOSFET and a transistor driver.
    Amit Ika likes this.
  4. Amit Ika
    Jul 4, 2016
    10
    I know this picture is kind of ridiculous but this is essentially my set up. The voltmeter is reading a max of 4 volts when the gate is at 5 volts and the voltage source is 12v.
  5. Amit Ika
    Jul 4, 2016
    10
  6. Amit Ika
    Jul 4, 2016
    10
    The mosfet is used to source the current. Any suggestions?
  7. Amit Ika
    Jul 4, 2016
    10
    Thanks for all the replies. Am I correct in saying that the transistor is in the wrong place? This should work If I switch between ground and load rather than between the voltage source in the load? Thanks.
  8. jpanhalt
    Jan 18, 2008
    5,699
    909
    In the design you post, it will be hard to make the mosfet source current. The reason is simple. When the mosfet conducts, the voltage drop across it is almost nil. That makes the voltage across the load equal the supply voltage, which is what you usually want, but that makes the source pin of the mosfet equal to the supply voltage too and means that the gate has to be even higher. There are ways to do that (e.g., charge pumps), and you can make a charge pump by toggling a pin on your MCU, but MCU's are often not tolerant to voltages that high (typically supply +5V or so).
    So, I recommend switching to a P-channel mosfet or connecting your N-channel Source to ground, Drain to the load (meter), and the other load(meter) terminal to the positive supply.
    I believe that is what you describe in your Post #7, which is correct.
    John
  9. ian field
    Distinguished Member
    Oct 27, 2012
    4,456
    792
    You can't use an N-channel MOSFET to source the current unless you provide a bootstrap gate supply - do as someone else suggested, use a P-channel MOSFET.
