Nope.Can a logic inverter invert a sine wave and/or pulse?
I built a NOT gate and a NAND gate to try this but neither seem to work. (NAND gate with both inputs being 1)
THanks
Nope.
A logic inverter inverts logic values 0->1, 1->0.
If you want to invert a sine wave, build a unity gain, inverting amplifier, or apply a 180° phase shift.
I built the logic gates with transistors thoughI would think it would work with square pulse, but you need to see what frequency the chip will work with. If the frequency of the pulses is too fast, then the chip will not do the job you want it to do.
Have you seen this: http://en.wikipedia.org/wiki/Inverter_(logic_gate)I built the logic gates with transistors though
