Logic Hi Impedance Tri-State Measurement
Discussion in 'General Electronics Chat' started by DexterMccoy, Feb 23, 2014.
Thread Status:
Not open for further replies.
  1. DexterMccoy
    Feb 19, 2014
    429
    For Testing Logic Circuits
    How do you know when a Logic output is an Hi Impedance? or tri-state?
    I don't know when a logic output is shorted to ground or Open internally on the output or if it's a Hi Impedance tri-state output
    How can I tell the difference? if the output is shorted to ground or it's open internally?
    Some Logic Probes will detect Tri state hi impedance, but how do you know if the output is shorted to ground internally or it's blown output has open internally? because it would measure the same
    What else can i use to measure Tri state or hi impedance outputs for logic circuits?
  2. alfacliff
    Dec 13, 2013
    2,449
    428
    a volt meter is usefull, also test for resistance. if shorted to ground, resistance would be very low, if just low output, voltage would probably be present, less than 1 volt. tristate outputs output normal levels for whatever family of logic they are till un enabled, then whatever else is on the line controls the voltage. if nothing else on the line, then output is a float voltage.
  3. MrChips
    Oct 2, 2009
    12,623
    3,451
    1) Take a 100kΩ resistor (or even higher depending on the impedance you are checking) and connect it between the output pin and GND while the output is supposed to be logic high. If you get 0V at the output pin then the output is high-impedance/disabled/not_working.
    2) Connect the resistor between the output pin and Vcc or Vdd while the output is supposed to be logic low. If you get Vcc or Vdd then the output is high-impedance/disabled/not_working.
    This is also a way to test the drive capability of the output. In this case you would gradually reduce the resistor value until the output fails to meet the output level specs.
  4. DexterMccoy
    Feb 19, 2014
    429
    If the logic chip is working, what voltage would I get?
    Isn't this going to overload the logic chip and damage it? by putting a 100K ohm resistor in parallel with the output of the logic chip?
  5. MrChips
    Oct 2, 2009
    12,623
    3,451
    Placing a 100kΩ load on the output of a logic gate will not damage it.
    Placing a 1kΩ load on the output will not damage it.
  6. DexterMccoy
    Feb 19, 2014
    429
    What value would start to damage the output of a logic chip?
Thread Status:
