Logic gates question
Discussion in 'Math' started by TaPaKaH, Feb 4, 2008.
  1. TaPaKaH
    Feb 4, 2008
    hi, i need alittle help here.i have a question.
    How can u have low exit when input is high, using AND and OR gates?
  2. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Just to clarify the question. Is this, how can you have a low output when one of the inputs is low, using AND and OR gates at the same time?
    Dave
  3. TaPaKaH
    Feb 4, 2008
    you have only high input and you must have a low output using ONLY AND and OR gates
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I do not think it is possible.
    If you DeMorganize the gates you will see this clearly.
    Low outputs require low inputs
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    No then. For an AND gate with one input tied to ground you will get a low output for a high (or low for that matter) input, but that is about it.
    Dave
  6. arthur92710
    Jun 25, 2007
    307
    An NOT or an inverter does what you need. High in Low out.
  7. Papabravo
    Feb 24, 2006
    10,340
    1,850
    That is quite true, but completely irrelevant since an inverter is neither an AND gate, nor an OR gate.
  8. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    My first instinct when I read the OP was, has the AND gate been confused with the NAND gate and the OR gate confused with the NOR gate - if so the answer is simple: to get a low output with a high input, just tie the inputs together - both the NAND and the NOR will then behave like an inverter.
    Dave
  9. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Well of course, but we should give the OP the benfit of the doubt, that he represented the question accurately.
  10. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    Agreed.
    Dave
  11. mik3ca
    Feb 11, 2007
    189
    because logic gates require at least two inputs, and you only specified one input (which is high), and you didn't specify the other input. We will have to make your other input low.
    you will have two outputs. One from the AND gate, and one from the OR gate.
    you specified that you want One of these outputs to be low.
    So walking through, we have:
    Logic high, ORed with Logic low = High output on the OR gate.
    Logic high ANDed with Logic low = Low output on the AND gate.
    Now if you said your other input was high, then both outputs will be high.
  12. James Sonroll
    Feb 22, 2008
    It is possible if you mean only one input is high and the output is low. Then, if you mean that all inputs and either one is high and the output is low, its impossible.
  13. aliashar86
    Nov 23, 2006
    71
    in the beginning dave gave a valid reason that ground the circuit nd u will get a low output
  14. aliashar86
    Nov 23, 2006
    71
    for further clarification u must see first the "Truth Table" of both AND nd OR gates
