logic gates - nmos
Discussion in 'General Electronics Chat' started by alexmath, Dec 5, 2014.
  1. alexmath
    May 2, 2014
    17
    Hey! Easy question for you guys. Why do we need both nmos and pmos transistor to build a logic gate? Why can't we just use only nmos transistors like bipolar logic gates?
  2. ronv
    Nov 12, 2008
    3,403
    1,477
    You can if you use an open collector output, but the classic totem pole output won't work very well because of the high gate to source voltage.
  3. kubeek
    Sep 20, 2005
    4,689
    806
    Because you would have to use resistors instead, and that wastes power and space.
  4. MikeML
    Oct 2, 2009
    5,451
    1,066
    NMOS for pulldown with resistors for pullup is called RTL (Resistor Transistor Logic). It was one of the first commonly available IC logic families. Hogged huge amounts of power.
    NMOS pullup requires a Gate voltage higher than VDD, so is not practical.
    PMOS pullup means that the transistor is turned-on by pulling the Gate to VSS, so coupled with NMOS for pulldown is the wonderful combination.
