Logic gates minimization
Discussion in 'General Electronics Chat' started by Dritech, Feb 15, 2013.
  1. Dritech
    Sep 21, 2011
    756
    5
    Hi all,
    From the attached schematic diagram, how can I do a NAND gates minimization?
    Thanks in advance.
  2. tshuck
    Oct 18, 2012
    3,531
    675
    Looks like you cut a couple minterms from the bottom there;)
    No worries...
    The easiest way would probably utilize DeMorgan's theorem in order to make the minterms into all NAND implimentations.
    You could also attempt to redraw the circuit with NANDs and try to reduce that way.
    Now, before you ask more questions, post some of your work.
  3. Dritech
    Sep 21, 2011
    756
    5
    Hi tshuck,
    I managed to do the NAND gate minimization, but is there a way to simplify the circuit (the one attached) ??
    (by the way, the photo shows a part of the circuit)
    Thanks.
  4. Dritech
    Sep 21, 2011
    756
    5
    Any help please? I tried using boolean algebra but I did not manage to minimize it while leaving all gates as NANDs.
  5. tshuck
    Oct 18, 2012
    3,531
    675
    If you did the work, post it....
    Also, your transformation to an all NAND implementation is wrong.
    See here
    specifically, this:
  6. kubeek
    Sep 20, 2005
    4,687
    805
    You should start by getting some minimal form of the input, and then translate the logic functions to gates. Also check if your requirement asks specifically for 2-input nand gates, that complicates things a little more.
  7. tshuck
    Oct 18, 2012
    3,531
    675
    Hint: You have to be comfortable with DeMorgan's Theorem to work the Boolean magic....
