Logic Gates Info!! :)
Discussion in 'Homework Help' started by Jover Paul Panaguiton, Jul 11, 2016.
  1. Jover Paul Panaguiton
    Jul 11, 2016
    Hi guys, this is my first time and i haven't read the rules, sorry if there is anything wrong about my post :)
    i just want to ask about Logic Gates!!
    My teacher gave us a quiz about this logic gate, and I'm confused about this variables!!
    CD and CD'
    are they the same? or not?
    by the way, this is the logic gate that our teacher gave to us >>
    {A+[B(CD')]}+E << Thank you :)
  2. AlbertHall
    Jun 4, 2014
    2,261
    447
    Do you understand what the apostrophe means in CD' ?
  3. Jover Paul Panaguiton
    Jul 11, 2016
    Yes :) in our study, we use it as a symbol for the logic gate NOT or INVERTER :)
  4. AlbertHall
    Jun 4, 2014
    2,261
    447
    So if you do truth tables for CD and for CD' you will be able to see whether they are the same or not.
  5. dannyf
    Sep 13, 2015
    2,196
    417
    CD x CD' = C x (D x D')
    And what is D x D'?
  6. AlbertHall
    Jun 4, 2014
    2,261
    447
    AND function is true if. and only if, all the inputs are true.
  7. djsfantasi
    Apr 11, 2010
    2,900
    870
    I don't think the OP meant AND, but simply "and". As in compare CD and CD' or in other words compare CD to CD' and determine if they are equal.
  8. Jover Paul Panaguiton
    Jul 11, 2016
    Thank you for all the reply's guys.. but i only need to know if there the same.. FROM YOUR OPINIONS!! .. i dont need to do truth table.. i just want to know if they are the same :)
  9. WBahn
    Mar 31, 2012
    18,085
    4,917
    Ah, I see. You don't want to understand whether or not they are the same or to make any attempt to figure out whether they are the same, you just want to take an opinion poll of what other people think and that's all the more effort you feel you need to put in.
    But, I guess that is quite consistent with not feeling any need to read the rules you agreed to when you joined.
  10. shteii01
    Feb 19, 2010
    3,500
    511
    CD
    00
    01
    10
    11 True
    CD'
    00
    01
    10 True
    11
    Are the above tables identical?
  11. Papabravo
    Feb 24, 2006
    10,338
    1,850
    Opinions are like elbows -- everybody has one. If our opinion was that you should fall down and cripple yourself -- would you?
  12. jpanhalt
    Jan 18, 2008
    5,699
    909
    Are you aware of the ability to express your question as a poll? That way, I could submit your question to Watter's World and give you the definitive polled result. I think the definitive answer would be huh? (option #3)
    John
  13. dannyf
    Sep 13, 2015
    2,196
    417
    CD xor CD' = C x (D xor D')
    And by definition, D xor D' = ?
    Done.
  14. Papabravo
    Feb 24, 2006
    10,338
    1,850
    General rule of thumb in symbolic logic. If two things are not syntactically the same, they cannot be semantically the same.
  15. AlbertHall
    Jun 4, 2014
    2,261
    447
    Opinions are like elbows - most people have more than one.
    Papabravo likes this.
  16. Jover Paul Panaguiton
    Jul 11, 2016
    oh my god, I'm sorry guys but there has been a Type ERROR!!..
    i mean CD' and (CD)'
    Aw... This is what I mean... tsk not this one > CD and CD' < SORRY GUYS!! there is some mistake, and I just make you guys a little bit confused :( sorry .. thank you anyways :)
  17. WBahn
    Mar 31, 2012
    18,085
    4,917
    Is there ANY chance that you're now willing to actually make some effort to try to answer your own question by doing a truth table for both of those and comparing them?
  18. hobbyist
    Distinguished Member
    Aug 10, 2008
    773
    62
    I think where your getting confused is that you see both CD together in both propositions, however use algebraic rules for parenthesis, that should help.
