Logic Gates and Karnaugh Map
Discussion in 'Homework Help' started by keviiii, Nov 27, 2008.
  1. keviiii
    Oct 17, 2008
    8
    hi to all,
    sorry blazedaces for the bad english, this is the edited version. hopefully it's better. haha.
    i have a question about logic gates and Karnaugh Map.
    qn: F = AB' + ABCD + ACD' + ABC' + AB + ABC + A'BD'
    i am supposed to find the minimised Sum-of-Product equation of the above using Karnaugh Map.
    however, after coming out with the Map, i dunnoe if it's correct to use 2 or 3 loops to find the equivalent equation.
    if i were to consider 2 loops, my answer will be:
    F = BD' + AD
    if i were to consider 3 loops, my answer will be:
    F = BD' + AD + AD'
    can someone help me out?
    thank you.
  2. blazedaces
    Jul 24, 2008
    130
    I have absolutely no idea what you're referring to ... maybe you could re-explain your question please?
    Unless someone else knows what is being talked about...
    -blazed
