Logic Gate symbols In WORD 2007
Discussion in 'The Projects Forum' started by JDR04, Nov 9, 2012.
  1. JDR04
    Thread Starter Active Member
    May 5, 2011
    339
    I hope this is the right place to ask this question......
    I'm doing my final assessment and am dealing with logic gates etc. What I need to know is how do I type in the A B and C with the bar on top? Hope I'm making sense.
    The other problem I have is how do I type in the gate symbols as well??
    I would be most garteful for any suggestions Thanks guys JDR04:confused:
  2. takao21203
    Distinguished Member
    Apr 28, 2012
    3,577
    463
    You don't.
    You'd use /A*/B.
    Or /(A*B).
    Depends on the equotation, you have to add a large number of brackets in some cases.
    The circuit diagram, you can use PAINT for simple one's, and insert a JPG.
    For larger schematics, you'd use a PCB design software, or a simulator like Proteus to draw it. Or a CAD software if you are professional.
    You should consider the Foxit PDF reader. It includes a plugin for Word! So it now can export to PDF with good results. Editing PDFs can be a pain, but Word is easy. Simply convert to PDF!
    JDR04 likes this.
  3. ScottWang
    Aug 23, 2012
    4,924
    777
  4. WBahn
    Mar 31, 2012
    18,079
    4,917
    What does ANY of this have to do with the OP's question?
    BTW, /ABC is poor form -- it's ambiguous. Does it mean (/A)(B)(C) or does it mean /(ABC). In general, the / has higher precedence than AND, as illustrated by your own second example since /A/B/C only means (/A)(/B)(/C) if you apply / first.
  5. spinnaker
    Oct 29, 2009
    5,063
    1,160
    I think I do.
    Basically an "overline : instead of an underline?
    You mean a "not" symbol. You could use !A for not A or ~A (which is a bitwise not and maybe more appropriate). This is how it would be done in C and Java.
  6. ScottWang
    Aug 23, 2012
    4,924
    777
    Thanks.
    That is my fault, comparing to the second expression, I posted that /ABC actually is /(ABC).
  7. Audioguru
    Dec 20, 2007
    9,411
    896
    No.
    NEVER use a fuzzy JPG file type for a schematic. Use a very clear PNG file type instead.
  8. JDT
    Feb 12, 2009
    658
    85
  9. spinnaker
    Oct 29, 2009
    5,063
    1,160
    You can do an Overline in Open Office. I would be surprised if you cannot do it in Word.
  10. djsfantasi
    Apr 11, 2010
    2,900
    870
    Follow these steps in MS Word to enter ~A:
    1) Press Ctrl-F9
    2) enter "EQ \x \to(A)" in the field between the braces (without the quotes; the area will be greyed out}
    3) press Shift-F9 to complete.
    To create other symbols, you can copy this one, paste and highlight it, right-click and select toggle field. Change the letter to whatever you need. This is limited to one level deep however. That is you cannot have something like ~(~A) or ~((~A)(~B)(~C)).
  11. panic mode
    Oct 10, 2011
    1,328
    305
  12. KyDave
    Jan 18, 2014
    Wow - thank you *so* much. I joined the site just to say that!
  13. crutschow
    Mar 14, 2008
    13,472
    3,361
    You can also use the insert>equation>accent and look for the overbar as described here.
