Logic gate design- Water pump
Discussion in 'Homework Help' started by rds1975, Aug 30, 2004.
  1. rds1975
    Aug 30, 2004
    8
    Hi all
    Can anybody give some inputs or ideas to design this one below :
    A water well pump is to be turned on automatically if the water level is low in
    any two or more of the three reservoirs it supplies. Each water level detector
    in the reservoir generate logic ‘0’ if the level in the reservoir is low.
    (a) Draw the truth table for the above function.
    (B) Express the output in SOP form.
    © Minimize the expression using Boolean laws.
    (d) Verify part © by minimizing the expression using K-map.
    (e) Realize the digital circuit using NOR & OR gates only.
    Thanks and regards
  2. trramesh
    Sep 27, 2004
    sir
    how we have to answer for the below , give some tips
    thanks and regards
    trramesh
  3. ramesh_ime
    Sep 25, 2004
    Hi trramesh,
    Just click "reply" which you can findout this reply button in top of each query.
    thx ramesh raju
  4. sauav raj
    Sep 28, 2014
    i want ans of this qus now
  5. djsfantasi
    Apr 11, 2010
    2,913
    881
    And I want get million $ now …
    Listen, I understand there are language barriers sometimes, but people are put off by rude statements. In fact, someone who comes across as rude, demanding, or otherwise unfriendly may never get an answer.
    In homework help, it is expected that you first attempt to get an answer in your own and present that work in your post. I often joke that this forum is NOT homework done for you. Secondly, rather than presenting an entire problem (quoted verbatim), it's best to break the problem into smaller pieces.
    Hope you are not offended , but I am really trying to help.
  6. Alec_t
    Sep 17, 2013
    5,980
    1,138
    You have resurrected a ten year old post! Are schools still setting the same old questions?
    djsfantasi likes this.
  7. sauav raj
    Sep 28, 2014
    wht is the ans of this qus
  8. MrCarlos
    Jan 2, 2010
    400
    134
