Supposing I want to build a circuit where a logic gate will light an LED. Naturally I'm interested in how much current I can get out of the gate to light the LED.
Looking at the datasheet for the CD4017:
http://www.ti.com/lit/ds/snos357a/snos357a.pdf
On page 2 it specifies "High level output current" as -3.5mA typical, under the conditions:
Vdd = 15V, Vo = 13.5V, 25 degrees temp.
Here's what I am wondering:
- Why is this figure negative? Surely a positive output voltage should give a positive output current?
- Is this the maximum permissible limit for the chip, or is this simply what it would deliver into a short circuit? In other words, could I run the LED with no limiting resistor, relying only on the IC's own current limitations?
