Greetings All,
Okay so this is actually more out of curiosity, given that It's my friend who needs the help and he thinks I'm 100% up to scratch with what I'm supposed to be doing when I'm not, which on reading that myself makes me realise I probably do need the help too.... Anyway! I was hoping some of you could give me some clues as to what to do.
So basically, we are trying to use a program called "Digital Works" to produce a logic gate circuit which utilises a 7-Segment LED display to progress between a total of 8 specific numbers. So say over a period of 8 seconds, a specific number is shown per second until the list is complete and it reverts back to the first number, a cycle basically.
We are using a 3:8 decoder layout, so 3 input and 8 output. The three inputs on this program are called "sequencers" which are basically bit generators.
What I would like to be explained to me is how I'm able to calculate and design the circuit so that the numbers I wish to be displayed, are so. I appreciate that you may ask why I can't consult the coursework brief or other course media for insight into how to do this, however I have done so and I've found there to be a significant lack of sufficient data to properly explain the process, at least in a way which I am able to fully understand and implement. Additonally, our tutors are currently on leave as Uni is out for summer, so I can't really communicate with them either.
Your help will be greatly appreciated and I'll be happy to provide any further information you may require.
Many thanks in advance!
