Logic Function
Discussion in 'General Electronics Chat' started by bronvang, Oct 21, 2009.
  1. bronvang
    May 26, 2009
    Could anyone tell me which Logic Function implements an even parity bit-generator for an n-bit word? :)
  2. Ratch
    Mar 20, 2007
    1,068
    bronvang,
    Why don't you make a truth table and simplify with a Karnaugh map?
    Ratch
  3. Papabravo
    Feb 24, 2006
    10,340
    1,850
    It is the inversion of the exclusive-or. The exclusive-or of an even number of 1's is 0 and the inversion of that is 1.
  4. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Maybe because that doesn't answer the question, never mind that there is no simplification, or that a Karnaugh map for 8 variables is intractable in 2 dimensions.
  5. Ratch
    Mar 20, 2007
    1,068
    Papabravo,
    The telltale checkerboard pattern would be visible on a 16 state K-map which is very doable. Easy to see that no reduction is possible, too.
    Ratch
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Yep they work well for 3 and 4 variable problems. After that it becomes dicey.
