logic circut bu BJT
Discussion in 'Homework Help' started by eng.mustafasalah, Mar 3, 2013.
  1. eng.mustafasalah
    Nov 10, 2011
    41
    http://im34.gulfup.com/CzXfF.jpg
    q4 - in the circuit shown what is the minimum RL that the invert can drive with out causing the output drop blew 4 V when Vi = 0V ?
    i don't understand what he want in Q4
    how i solve question 4 ?
  2. Brownout
    Jan 10, 2012
    2,375
    998
    I don't understand it either. In fact, I can't even read it.
  3. eng.mustafasalah
    Nov 10, 2011
    41
    i write the q4 ...
  4. Brownout
    Jan 10, 2012
    2,375
    998
    OH, he wants you to provide the minumum resistance for RL which the inverter can drive without causing the output to drop below 4V when Vi=0. Vi is the input voltage to the inverter.
  5. eng.mustafasalah
    Nov 10, 2011
    41
    ok
    how i prove that ? do you know ?
  6. Brownout
    Jan 10, 2012
    2,375
    998
    Well, when the input voltage = 0V, is the transistor on or off? If it's on, then you need to derive an expression for output voltage with the transistor on. If it's off, then you need to derive an expression for the output voltage with the transistor off.
  7. eng.mustafasalah
    Nov 10, 2011
    41
    thank uuuuuuuuuuuuuuuuuuuuuuuuuu
