Logic Circuits
Discussion in 'Homework Help' started by gsanjaya, Jan 18, 2016.
  1. gsanjaya
    Jan 18, 2016
    A Screen Shot 2016-01-18 at 23.47.45.png A Screen Shot 2016-01-18 at 23.47.55.png nalyse the logic circuit shown in Figure 2. The inputs to the circuit are C0, A0, B0, A1, B1, A2 and B2. The outputs are S0, S1, S2 and C3. The internal structure of the logic block in the middle of Figure 2 is shown in Figure 3.
    Mod edit: Moved to Homework Help
  2. Kermit2
    Feb 5, 2010
    3,851
    967
    Do you know the truth tables for the various logic gate types shown in your problem?
    If you do then start with all inputs at 0 and follow them through to the output. Create another larger truth table for the assignment and list all inputs and outputs.
    This one will take a few hours of your time.
    If you just want someone to give you answers, then you need to seek for them elsewhere. We are here to help you do it yourself and not to do it for you.
  3. WBahn
    Mar 31, 2012
    18,087
    4,917
    What is meant by "analyze the logic circuit" in this problem? Are you expected to come up with equations for each of the outputs in terms of the inputs, or would a truth table for the circuit suffice?
    If a truth table would be sufficient (which would have 128 rows), then you could construct it pretty quickly in a spread sheet.
    If they want equations, then do it is stages. First get equations for the outputs of the boxed circuit in terms of the inputs to the boxed circuit. Then get equations for the inputs to the boxed circuit in terms of the overall inputs. Then get equations for the overall outputs in terms of the outputs of the boxed circuit and inputs to the boxed circuit. Then combine them together.
    It shouldn't take too terribly long -- perhaps half an hour or so. There is actually a lot of structure in the circuit that makes it reasonable straightforward.
  4. dl324
    Distinguished Member
    Mar 30, 2015
    3,378
    651
    OP resurrected this 5 year old thread that had the same logic diagrams. It included this additional information
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    Interesting. I was going to ask if they were supposed to figure out a simple description of what it does, such as adding two three-bit inputs A and B, but decided that that would risk running things off on a tangent.
    I'm assuming that the circuit is an assignment that is given by some prof periodically. Out of curiosity, how did you spot that prior incarnation?
  6. WBahn
    Mar 31, 2012
    18,087
    4,917
    Never mind -- I see how you spotted it.
  7. WBahn
    Mar 31, 2012
    18,087
    4,917
    Gee, looks like I even guessed what it does (and it was pretty much a guess that I didn't really think was likely to be correct).
  8. dl324
    Mar 30, 2015
    3,378
    651
    I'm curious how the OP found it.
  9. WBahn
    Mar 31, 2012
    18,087
    4,917
    Good question, though when you read a thread here you get the "Similar Threads" list at the bottom and they are almost always many years old. So they probably did a search and then explored the threads listed at the bottom.
  10. WBahn
    Mar 31, 2012
    18,087
    4,917
    @gsanjaya : I see that you are only 17 years old, and that is pretty young compared to most people that are learning this stuff. Are you learning this in high school (or whatever the Australian equivalent is) or are you taking college courses?
    How comfortable are you with Boolean expressions involving NOT, OR, and AND? Are you comfortable with expressions involving XOR?
  11. WBahn
    Mar 31, 2012
    18,087
    4,917
    I don't know how reasonable I think it is for a student (or most anyone else) to be able to look at a bunch of low level logic equations and divine what high level conceptual function they implement, so don't feel too bad if it isn't apparent to you. Hopefully this problem was given within a context that really narrows things down. Certainly the choice of names for input and output signals is a pretty big hint.
