logic analyzer
Discussion in 'Electronics Resources' started by Seramai, Apr 26, 2014.
  1. Seramai
    Apr 26, 2014
    6
    Not sure how to connect Logic Analyzer to develop truth table. New to EE.
  2. Alec_t
    Sep 17, 2013
    5,968
    1,135
    People don't like opening zip/rar files. Can't you post the contents in another format? (png or gif is good for schematics).
  3. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,385
    The file inside the zip has a .ms12 extention.
    I assume this is from multisim.
    Not many will have the software, so post the schematic in .png format.
    A screenshot would also do.
    Bertus
  4. Seramai
    Apr 26, 2014
    6
    Here it is again. I should have said logic converter instead of logic analyzer.
  5. Alec_t
    Sep 17, 2013
    5,968
    1,135
    What is the 'logic converter' supposed to do?
  6. Sparky49
    Jul 16, 2011
    835
    417
    Hi there,
    I have to use multisim for uni... Yes, it is rubbish, and yes the logic converter is stupid...
    To get it to work, connect your inputs, working form the leftmost pin, to the logic converter. Connect your circuit's output to the rightmost pin.
    Then, double click the logic converter. Chose the inputs you want to use (A,B,C, etc), then click on the first button under 'conversions'.
    Hope this has been helpful.
    Sparky
  7. Seramai
    Apr 26, 2014
    6
    Any thoughts on this. This is still a struggle.
  8. Alec_t
    Sep 17, 2013
    5,968
    1,135
    I've never used Multisim so can't really advise, but would comment that your circuit is 'back to front' compared to conventional layouts. Conventionally clock U3 would be on the left and the ICs would be, from left to right, U1a, U2a, U5a, U4a. Perhaps if you re-arranged the sequence of inputs to XLC1 to match the conventional layout you might get the converter outputs you expect?
  9. Sparky49
    Jul 16, 2011
    835
    417
    First of all, you have connected four inputs to the converter, but have only chosen B, C and D. What about A?
    Did you click the first button under "Conversions"?
