Logging voltage/current, maybe with Android
Discussion in 'The Projects Forum' started by Lectraplayer, Jul 11, 2015.
  1. Lectraplayer
    Jan 2, 2015
    77
    5
    This is currently an unexplored idea for me, but I would like to know some ways of logging voltage and/or current over a 24 hour time refrence. While I will begin with my solar power experiment, I can think of at least 100 other projects to quickly put that capability to use. Being able to link to an old Android (Froyo) smartphone also sounds like it could prove useful. What would be some options to investigate, so that I don't spend countless hours hunting the wrong patern?
    Solar power experiment: http://forum.allaboutcircuits.com/threads/how-to-figure-solar-capacity-as-added.113230/#post-879167
  2. pwdixon
    Member
    Oct 11, 2012
    488
    56
    You could use an arduino to read voltages and current with a bluetooth link to your smartphone. App inventor is a free environment to develop an android app that could accept your voltage data.
  3. paulktreg
    Distinguished Member
    Jun 2, 2008
    624
    125
    I have a Precision Gold N56FU DMM with USB interface i bought from Maplin a while back. (No longer stocked by the look of it).
    It came with PC software and will log voltage or current over time.
    Worth looking into if you can find something similar.
  4. DickCappels
    Aug 21, 2008
    2,773
    669
    if you phone doesn't already have a voice memo recorder application, you can probably get one. Then, all you need is a voltage-to-frequency converter and a few other parts for recording, and a frequency-to-voltage converter for playback.
    You could also the function of cycling among these three: 0V Full scale V, and the measured V. The playback circuit would use this information to assure calibration.
  5. pwdixon
    Member
    Oct 11, 2012
    488
    56
    I'm pretty sure that was a joke. At least I hope so.
  6. DickCappels
    Aug 21, 2008
    2,773
    669
    Thank you for the feedback. Why do you think and hope that is a joke?
  7. sirch2
    Jan 21, 2013
    1,008
    351
    I've mentioned this on here before but a couple of years ago I wrote an OCR application for reading and LCD in Android, point the phone's camera at a DMM display OCR the reading.
    That said I also like Dick's idea.
    The Arduino-Bluetooth-Android idea pwdixon suggests is also one I have used in the past, it is a bit more complex but probably the one that you will find most help on the web for and there are android apps available for bluetooth-serial data. If you have never written an Android app the learning curve is quite steep so having an example can be useful.
