Logarithmic amplifier
Discussion in 'Homework Help' started by chitofan, Nov 1, 2012.
  1. chitofan
    Sep 30, 2012
    15
    Hi, can anybody tell me what kind of voltage error does a diode introduce into a logarithmic amplifier?
    As far as i can guess, the diode can be modelled as a voltage source of 0.7v (usually) and would add on to the offset voltage, so there's your DC error?
    I have found this to the best reference with regards to a basic diode-connected log amp (link), but we have not been taught to understand op amps on a transistor level so the meaning is not very clear to me. Any hints would be greatly appreciated.
    Just to clarify, my homework assignment is to design an op amp through calculatation of the Vout error of an logarithmic amplifier. I'm not sure how the diode will have an impact on the omp amp output in the form of an error.
  2. panic mode
    Oct 10, 2011
    1,328
    305
    characteristic of the diode changes with temperature for example and it also has noise
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
    I actually designed and built a pretty accurate log amp to convert the audio input signal into log scale to show on a meter. The circuitry reveals a lot of where errors come from (see attached schematic). Also included is data from testing the log amp plotted on log paper to show it's accuracy.
    Components U1-C up to Q2 are a peak detector so the signal applied to the log amp is basically DC or slowly changing AC, since log amps have very limited bandwidth. U1-D, Q1, Q3, and Q4 make a log amp. Q1, Q3, and Q4 are diodes (transistors wired as diodes) chosen for very close VBE values to minimize DC offset error to the following amplifier stage.
    Since the output of U1-D goes through R11, it basically converts the input peak voltage into a current through Q3. The following stage amplifies the difference in voltage across the two diodes Q3 and Q4. Since the voltage change across a diode follows log scale as the current changes, this creates a log amp.
    R18 on the following stage nulls out the DC offset.
    The data curve shows the total accuracy from input all the way out to the meter.
  4. chitofan
    Sep 30, 2012
    15
    Hi, thanks for the responses :) I'm not sure what to make of the info given because i haven't learned that much, and my problem involves a basic-diode log amp model.
    My homework assignment is basically just about DC imperfections so we can ignore other factors and so i focus purely on the impact of my choices for Rin, Rx and the chosen op amp parameters (Ib, Ios)
    Here's my revised attempt at a solution
    Using superposition theorem, we calculate the effects of Ib, Ios and Vos (RTI) separately and we get the total Vin/Rin (we need to express the error in terms of Iin) as
    (Id + IB1 - ((IB2 * Rxx) / Rin)) (Ib effect)
    (Id + (Ios/2)(1 + Rx/Rin)) (Ios effect)
    (Id + Vos/Rin) (Vos effect)
    Herein lies my dilemma, how am i going to work in these 3 Ids? So i turn to my lecturer's hint.
    Since there is no value to substitute for Id in the error analysis, we calculate Vout in terms of Id (perfect and error values)
    I derive the ideal op amp equation as Vout = -Vd = -25mV ln (Id/Is)
    (Vt = 25mV)
    Iperfect = Is * ln (Voutperfect/Vt)
    Ierror = Is * ln (Vouterror/Vt)
    Ierror/Iperfect = ln (Vouterror/Vt) / ln (Voutperfect/Vt)
    This is the RTO gain, to convert it to RTI (for expressing error in terms of Iin) we divide it by the gain. But what is the gain when you have a diode in place of a resistor? Do we use the open loop gain, in which case i cannot find in an op amp datasheet (or at least i cannot find it)?
    Now i am truly lost. Can someone give me some idea as to what is it that i have derived from algebra?
  5. HonT
    Oct 25, 2012
    14
    You won't want to use the open loop gain because that is used only in the case where there is no feedback in the circuit
  6. chitofan
    Sep 30, 2012
    15
    Then, how do you calculate the gain of a op amp with only 1 resistor? The general equation is (1+Rf/Ri) so how do you replace the Rf in place of a diode?
  7. crutschow
    Mar 14, 2008
    13,472
    3,359
    The diode equation replaces Rf. Thus the gain is [(diode eq)/Ri]. (The 1 in your equation is for a non-inverting amplifier, not an inverting amplifier that you show). The output voltage is thus a logarithmic function of the input voltage.
  8. chitofan
    Sep 30, 2012
    15
    I'm sorry if this is a dense question, but does that mean the gain is in amps (say, if i substituted 0.7v into Vd)? I understand 0.7v is a good measure of Vd for silicon diodes, but does the value change in an actual log amp?
  9. MrChips
    Oct 2, 2009
    12,623
    3,451
    Of course it does. That is why it is a log amplifier.
    And that is why you cannot get accurate results because it depends on the reverse leakage current and it is also highly dependent on temperature.
  10. dinomadsaur
    Nov 8, 2012
    Hi sorry to intrude,
    If Vd is given to be 25mV*ln(Id/Is) and the diode is a generic with non specified Is.
    Is there a optional/alternative to calculating gain? or is it even necessary?
    As his objective should be to calculate for Vout_error to not exceed 10mV
    On the side note what does fractional error=(Ierror/Iperfect) represents? Can I use Vin*fractional error to get Vout_error
You May Also Like:
Load More
