Logarithm
Discussion in 'Homework Help' started by serial2222, Dec 27, 2014.
  1. serial2222
    Dec 27, 2014
    9
    hi friends
    i have problem with logic works
    i need Logarithm circuit with "logic works"
    can someone help me????
    plzzzzzzzz
  2. WBahn
    Mar 31, 2012
    18,079
    4,917
    First, what kind of logarithm circuit are you talking about? Analog, digital, ...?
    This is not the Homework Done For You forum. You need to show YOUR best attempt to solve YOUR homework problem. We will then help guide you along the path to the solution if we can.
  3. serial2222
    Dec 27, 2014
    9
    i exactly dont know what kind ? analog or digital? :(
    but i not one kind electric circuit diagram can be design with logic work
    like this : http://t0.gstatic.com/images?q=tbn:ANd9GcSHOVeCKma5-JakuSBwuYzJ0m3N7vFPyE-Qq4Lm494X1M5c0IMo
    but i say i become dizzy :((
    help me plzzzzzzz
  4. WBahn
    Mar 31, 2012
    18,079
    4,917
    So what, exactly, is the assignment?
  5. serial2222
    Dec 27, 2014
    9
    Log 2 (A) + Log 2 (B )
  6. WBahn
    Mar 31, 2012
    18,079
    4,917
    How are A and B represented?
    serial2222 likes this.
  7. serial2222
    Dec 27, 2014
    9
    in digital mode
  8. WBahn
    Mar 31, 2012
    18,079
    4,917
    Again, how are the values A and B represented? Unsigned integers? Two-complement? IEEE Floating point?
    What, exactly, is the assignment?
  9. serial2222
    Dec 27, 2014
    9
    two - comlement ==> true table ===> karno ===> equation ===> circuit
  10. WBahn
    Mar 31, 2012
    18,079
    4,917
    Okay. So focus on taking the base-2 logarithm of a two's complement number.
    What representation is the output supposed to be in?
  11. serial2222
    Dec 27, 2014
    9
    yes.
    in seven segment
  12. WBahn
    Mar 31, 2012
    18,079
    4,917
    "seven segment" is not a representation format. A representation format is something like "unsigned binary", "twos-complement", "IEEE-754 single-precision floating point", "fixed point".
  13. serial2222
    Dec 27, 2014
    9
    oh ye
    twos-complement and show result in seven segment
  14. WBahn
    Mar 31, 2012
    18,079
    4,917
    Okay.
    So what should the output of your circuit be if the input is 5? What should be displayed?
    What if the input is -12?
  15. serial2222
    Dec 27, 2014
    9
    shows error
  16. WBahn
    Mar 31, 2012
    18,079
    4,917
    For both cases?
    How does it show an error?
    What values of input should it NOT show an error for?
  17. serial2222
    Dec 27, 2014
    9
    :confused:
    more intricacy accord
  18. WBahn
    Mar 31, 2012
    18,079
    4,917
    I don't understand what you are saying here. I suspect it is just a language barrier problem, so try rephrasing.
    You said that if you have an input value of 5 that the output should show error. So in response to that I have two questions:
    Why should the base-2 logarithm of 5 produce an error?
    How will you show an error on your 7-segment displays?
    In addition, I asked you to describe what input values (at least give an example or two) should not produce an error and what the output values should then be.
