Lock In Amplifiers
Discussion in 'General Electronics Chat' started by shahdeep, Aug 13, 2015.
  1. shahdeep
    Aug 13, 2015
    Dear Users,
    I am working on EQE measurements and we have a lock in amplifier which uses voltages as input source. But the EQE setup that we have has DC modulated current. So I need to know what kind of circuit will be useful for my setup to have a linear voltage response to the change in DC current.
    Thank you in advance.
    K.R,
    DS
  2. Brainbox
    Member
    Nov 15, 2010
    25
    For linear conversion from current to voltage You wil need a linear resistor to do the conversion and a capacitor to shift out the DC component.
    Most common resistors are linear.
    Btw; what is ment by EQE measurements ?
  3. DickCappels
    Aug 21, 2008
    2,775
    673
    What is the impedance of your current source?
  4. shahdeep
    Aug 13, 2015
    EQE: External Quantum Efficiency, used for solar cell measurements.
    I have not measured the impedance yet but my working range is 100uA to 50mA.
    Thank you once again.
  5. DickCappels
    Aug 21, 2008
    2,775
    673
    If the output impedance is very high you can simply measure the voltage across a resistor as Brainbox suggested.
    If you run the solar cell into a dead short instead of a resistor you will be able to obtain consistent results regardless of the output impedance of the cell. A transimpedence is the classic way of accomplishing this. The voltage at the output is equal to I x R while the cell looks into a virtual short circuit.
    An op amp such as the SGS-Thompson Semiconductors L272M can supply more than the needed 50 ma.
    Bob Pease's take on it:
    http://electronicdesign.com/analog/whats-all-transimpedance-amplifier-stuff-anyhow-part-1
  6. shahdeep
    Aug 13, 2015
    Thank you so much. I will read about it and let you know if anymore doubts.
