lock-in amplifier AD630
Discussion in 'The Projects Forum' started by przemmo, Jan 11, 2009.
  1. przemmo
    Jan 6, 2009
    8
    I want to use this part to detect low fluorescence over the human skin surface. Has anyone worked with the modulator/demodulator? Will I meet any problem?
    For example simple circuit from the application note of AD630 (please find the jpeg)? I want to replace the bridge and instr. apm. with a light-to-voltage transducer with a gain stage. Do I need any phase shifter to adapt the phase of the gain stage to the reference generator signal?
  2. przemmo
    Jan 6, 2009
    8
    Why no answer? Did I write something stupid?
  3. KMoffett
    Dec 19, 2007
    2,584
    234
    Perhaps you could post the schematic of the front end you want to add. Otherwise, it's impossible to determine if a specific circuit creates a phase inversion problem. The more information you provide, the more likely you are to get a practical answer.
    Ken
  4. przemmo
    Jan 6, 2009
    8
    Phase inversion is one phase shift is something other. What I want to ask is if I have to tune the phase of the signal to the phase of generator used. Every amplifier, even cables creates some phase shift. I want to know if this is a problem or it's neglegible shift. The front end is just a photodiode with transimpedance amplifier (feedback resistor say 10-50Mohms) connected to the AD630.
