Local Oscillator Design (heterodyne) for FM reciever
J.o.s.h
Joined Oct 8, 2014
7
Hello, pls i need help on the desingn of the above stated project. i really cannot tell what heterodyne means and how to go about the whole design, including design of power supply for the circuit. pls help as soon as possible. FETs would be appreciated. tanx in anticipation
J.o.s.h
Joined Oct 8, 2014
7
http://en.wikipedia.org/wiki/Heterodyne
Read this article. This does an excellent job of defining heterodyning. If this doesn't make sense, then I would suggest you move to a less complex circuit design and work your way up.
http://www.talkingelectronics.com/te_interactive_index.html (Select: 27MHz receiver 2 channel)
This is a low power, cheap, well documented design that is perfect for a beginner in radio circuitry.
oh well tanx for posting, but ive read the wiki site b4, at least some of it. i do understand what "heterodyne" means. my aim is to design a local oscillator for fm reciever using a FET , using any convenient oscillator type. any circuit diagram with explanations would do.tnx
b1u3sf4n09
Joined May 23, 2014
113
Dang, now that's some fast learnin'...
In all seriousness, your request is not a small task. Engineers are paid large (*cough) amounts of money to design the circuit that you are requesting. Maybe if you could define the radio you want to build (frequency, power), we could help you get started.
J.o.s.h
Joined Oct 8, 2014
7
oh tanx every1 for suggestions
why not use an se602 chip? a built in oscilator and mixer.
i have been constrained to use FETs for the LO
I have a picture copy of a local oscillator (voltage controlled) for FM reciever but built with BJTs. i would appreciate if any one can EXPLAIN the circuit to me and suggest how to introduce FETs in place of the BJTs. the full document can be found on this link. http://www.eit.lth.se/fileadmin/eit/courses/eti041/VT2011/04a.pdf
J.o.s.h
Joined Oct 8, 2014
7
hello please i would love to have a clapp instead of the colpitts. i need to hit frequency of 119mhz but I am still around 2mhz wit this cct.
can anyone advise on the values of capacitors and resistors thatll give the req. frequency?
k7elp60
Joined Nov 4, 2008
562
I would recommend changing c2 and c5 to approximately 30pf, and changing c6 to 30pf and L2 to 6uh.
k7elp60
Joined Nov 4, 2008
562
I ended up with a somewhat unstable triangular waveform of about 50khz.
The only other things I can suggest is to remove C1 and D1, Change C9 to 100pF and where L2 connects to R2 replace that junction with a 1000pf capacitor.
One important thing is the construction, it needs to have short leads from each component. Building it on a solderless bread board will not work. You may have to increase the supply voltage. If you have an adjustable power supply increase the voltage to about 9V.
