loading hex file into a microcontroller
Discussion in 'The Projects Forum' started by rojosa, Mar 15, 2014.
  1. rojosa
    Mar 15, 2014
    i know we have to use flash magic to load a hex file into microcontroller,
    i have a designed a microcontroller kit,everything is right as far as i know,even the professors say the circuit is right,i have checked voltages at every required point to see if the microcontroller is getting the voltage or not.....everything is checked.but the problem is,no program would load in my p89v51rd2....
    i really need some help.
    i am using max232 to drive the controller and rs232 as serial communications....
    thanks in advance.
  2. GopherT
    Nov 23, 2012
    6,297
    4,019
    Without a schematic and some photos of your circuit, there is not much we can do to help you.
  3. DickCappels
    Aug 21, 2008
    2,746
    665
    rojosa likes this.
  4. rojosa
    Mar 15, 2014
    ok,i'll post a photo of my circuit soon.
    thankyou
  5. Ian Rogers
    Member
    Dec 12, 2012
    158
    29
    I'm sure I had a switch on EA pin or something so when it resets it goes into bootloader mode...
    rojosa likes this.
