1. stacymckenna
    Nov 26, 2007
    5
    Having completed the volume on DC I'm now working my way thorugh AC and hit a comprehension snag in Chapter 9. In section 9.1 you refer to a "heavier load" of 15 Ohm compared to a "lighter load" of 1 kOhm. Again in 9.6 you refer to a "heavy" 200 Ohm vs a "light" 1 kOhm. My brain shorted out. Am I incorrect in that we'd previously been referring to heavier resistances as higher/heavier loads? I understand the concept that a lower resistance means more current flow/power draw, but it was completely counterintuitive for me, and requires a conscious step of mental translation every time the text refers to a higher resistance as a lighter load. I would swear that circuit analysis in the DC volume referenced higher resistance loads as heavier. Is it a difference of DC vs AC? Did the vocabulary suddenly shift at this point in the text resulting in this confusion? Did we flip from referencing the "[resistance] load" to referencing the "[current] load" without specifying what the unwritten modifier should be?
  2. redwin88
    Member
    Dec 17, 2007
    11
    Keep the focus on what you wrote below (it is true).
    Stacymckenna wrote:
    "... lower resistance means more current flow/power draw..."
    Don't worry about subtle grammar issues.
    What really matters is that energy usage will increase, whenever
    the resistance is decreased in a circuit (that’s an inverse relationship there).
  3. recca02
    Apr 2, 2007
    1,211
    the sooner you can get that the better, else it creates a lot of confusion later.
    u can consider a ac outlet having lot of bulbs in paprallel.
    even though resistance f each bulb is same effective resistance is
    (resistance of one bulb)/n..n being the number of bulbs.
    and the total power supplied to bulbs is n*(power of 1 bulb).
    and the total current for same terminal voltage is now n times initial.
  4. stacymckenna
    Nov 26, 2007
    5
    I understand the lower resistance/higher current relationship. My concern is that the point of a textbook/manual is to make concepts clear and understandable, and if how things are described for over 500 pages previous suddenly makes a very basic concept confusing... then it might be worth looking into how to reword things throughout so that all of the concepts are clear and easy to understand. When a "subtle grammar issue" makes thing confusing, I think that's a rather important grammar issue.
  5. recca02
    Apr 2, 2007
    1,211
    was there such an error?
    in both of above quotes, lesser resistance was treated as heavier load.
  6. stacymckenna
    Nov 26, 2007
    5
    Both specific examples referenced a higher current load, yes. My point is that the previous 500 pages of text had trained my brain to think of a higher RESISTANCE load as a "heavier load", so as far as intuitive thinking, the sudden reference to CURRENT load required a 180 in how my brain translated things. Technically speaking, none of the wording has been inaccurate, it's just resulting in confusion because of [I believe] a lack of specificity or consistency somewhere between the first volume and second. Hence my original comment asking for clarification on how things were referenced in the previous Volume/chapters.
  7. redwin88
    Member
    Dec 17, 2007
    11
    I went back and re-read the original post.
    In that post (sentence number 4) Stacy asks...
    Yes, it is true... you were incorrect (about that one thing).
    A "heavy" resistance will only allow a small amount of current to
    flow, which leads to a "light" load on that circuit.
    The rest of the things Stacy wrote about were well constructed,
    communicated, and show wonderful logic with thorough integration.
    That; is why I'm writing, to share that (I hope) I've found a way
    to help by spotlighting the (logic) "error" in the original post, as I do not
    believe previous references (to resistance/loads) were as she remembered.
  8. Dcrunkilton
    E-book Co-ordinator
    Jul 31, 2004
    416
    11
    I have modified the master copy at ibiblio by addition of (higher current) next to the heavy load references and (less current) next to the light load references.
