Hello all,
I am trying to build a load transient board where the DUT has floating outputs. For that I'm using an NMOS which is driven by an op-amp (OPA27) and a 1Ohm sense resistor. The voltage across the resistor is fed back in the negative input terminal of the op-amp.
The circuit in this configuration is working. However I wanted to isolate the input signal and for that I used an 1:1 isolation transformer (T6437-DL ). And it appears that I can't use this transformer at 10 kHz, and if I increase the frequency I have a problem with the op-amp. I tried everything I could imagine of, so now I think I need your help. I have attached image I took during tests.
Thank you for your help,
dD
dD
