load tester
Discussion in 'The Projects Forum' started by ken_678123, Oct 21, 2013.
  1. ken_678123
    Oct 21, 2013
    Hi
    I am looking at building a variable load tester for testing batteries and need to incorporate a variable load in the design ..can any one advise what compnanent can be used to acheive this The load should range from 0 - 12amps at 12v
    THANKS
    kEN
  2. Alec_t
    Sep 17, 2013
    5,967
    1,135
    Do you intend to vary the load manually (e.g. by selector switch) or automatically?
    What resolution (step change) in load is required?
    What accuracy?
  3. #12
    Nov 30, 2010
    16,665
    7,310
    Do you realize you're looking at 150 to 200 watts?
    That size of resistor is rather expensive.
    $75 for the rheostat and $28 for the limiting resistor (1 ohm, 300 watts)
    If size doesn't matter, a bank of headlights might be good enough.
    Whaddaya think?
  4. wayneh
    Sep 9, 2010
    12,374
    3,226
    That's what I'd do; 2 headlights would be close to 10A. Visual feedback, good heat dissipation. You could get fancy with an adjustable, constant current controller.
  5. ronv
    Nov 12, 2008
    3,393
    1,449
    On another forum we have done a couple with FETs soldered to copper pipe using water to cool them. You could also do the same thing with some really big heat sinks.
