It is a plastic box. No green wire, just the bare ground wire. It is installked in Florida, USA.If you put in a country location when you registered, we wouldn't have to play twenty questions!
Is the box that it is going into metallic or plastic?
Is there a green wire in the box?
part number of timer?
Did you try reading the manual?
The only thing unclear is the function of the "load line" in the timer..
Which might be for devices that are downstream of the switch that you don't want on the timer or vice-versa.. Manual should call it out or have a diagram..
Utilitech, PN 0141224. Nothing in instructions. Notrhing downstream of the lights being switched.part number of timer?
Max.Are the outside lights low voltage?
Might be time to brush up on the reading skills..Utilitech, PN 0141224. Nothing in instructions. Notrhing downstream of the lights being switched.
If so it maybe the type that typically has a isolated supply and in that case low voltage can be ran without ground.
If mains powered then you should have a service ground that leaves the timer.
Max.
Thanks.Box-blk is power into the timer. The blk wire? that goes outside to the lights goes to the load terminal on the timer..
Box-wht is neutral, goes to com side of the timer and to the wht. wire to the outside lights.
Box-bare is ground, goes to gnd terminal on the timer and to the outside lights.
Thread starter | Similar threads | Forum | Replies | Date |
PC PSU max load | General Electronics Chat | 7 | ||
D | Step up Dc-DC and inductive load pump | Power Electronics | 34 | |
J | Help with designing a roof snow load sensor and app… | General Electronics Chat | 27 | |
A | What is the capacitive load? | PCB Layout , EDA & Simulations | 14 | |
uneven load on lead-acid batteries | Power Electronics | 9 |
by Duane Benson
by Duane Benson
