I have a switched circuit providing voltage to the base of a TIP. The TIP drives a load off the same battery. My problem is trying to add an led to notify me if the load has faulted (broken connection). I've tried to have the load circuit provide signal to base of a pnp transistor with an led and resistor (using the same battery) but it never works properly.
My understanding was the pnp would keep the led on constantly unless it received a signal from the base (which would be when the load is working). But there must be something I am missing since this setup does not work when I disconnect the load. I have tried using the pos and neg lines (from TIP pins) for the base on the pnp but they both really come straight off the same battery to begin with as the TIP merely connects them to run the load.
I have also tried the simple blown fuse indicator of routing an led and resistor parallel to the load but this is impossible to get the correct values since the load resistance can vary based on the specifics of the load the user chooses. At the best of the worst, this method might yield a very dim led. Hence, the dilemma.
