Hello all,
We have a sealed oxygen tank. We have to measure the liquid level of the tank. There is already an existing solution where Load cells are used to measure the current weight of the tank and they subtract with the total weight of the tank and find the proportional liquid level. Four load cells are used at four ends of the tank. This makes the set up so costly.
I came across this document (http://www.google.co.in/url?q=http:...LNJlyA&usg=AFQjCNF3YsUwW8eajkFZXxKuA0leNoHryg)
which explains two pressure sensor can do the job.
How practical the solution is?
Using two pressure sensors to do the job a good idea?
Help is much appreciated.
Regards,
Avinash
Regards,
Avinash
