Howdy,
I am a mechanical engineering student with limited circuitry knowledge to start...
Anyhow I have a [-500,+500]lbf load cell that is essentially a wheatstone bridge strain gauge. I want to give it either 9Vdc or 12Vdc excitation voltage since I have a regulated power supply that can output those voltages. The load cell is rated for 10V excitation with a maximum of 15V though.
Anyhow here is my problem. I am using a NI USB 6009 DAQ to record the voltage output from the load cell. At zero load I tested the voltage outputs for both 9V and 12V input excitation voltages.
9V input -> 4.19V output
12V input -> 5.65V output
The Full Scale range of operation I hope to use this load cell in would result in a maximum/minimum increase in output voltage to
9V input -> 4.19V +/- 0.027V output
12V input -> 5.65V +/- 0.036V output
The other device I have is the USB 6009 DAQ that can ready +/- 10Vdc but it has limited resolution, if I hook the system up to the DAQ without conditioning the output signal I only get +/-5lbf output accuracy and that is when sampling at 1hz. I would like to maximize how fast I can sample and greatly improve the output accuracy. So I figure I need to "zero" the output voltage with a circuit and I suppose scale the output up to +/- 10V.
I hope I am not asking too complex of a question. I just don't really know where to begin. All I have come up with so far is:
-Low Noise Op-Amp to apply a GAIN to the output signal and power it with the DC voltage source
-Use a voltage divider circuit in parallel with the excitation source voltage to "zero" the output voltage.
I must not be doing any of it right though since the circuits I have thrown together from guides on the net have not done anything that I am wanting them to do .
Any help on where I need to look now?
Here is some other info on the load cell
Nominal Input Resistance: 394ohms
Nominal Output Resistance: 350ohms
