load cell problem
Discussion in 'General Electronics Chat' started by chidari max, Sep 5, 2012.
  1. chidari max
    Sep 5, 2012
    hi, i have a load cell problem on a packing machine. the machine use two load cell connected in parallel but one load cell is always after working for two weeks. at one time i changed all the two load cell but the problem was not eliminated
  2. chuckey
    Jun 4, 2007
    75
    10
    This is a vague problem, is it the same one that is failing? how are they fed? Normally when two devices are in parallel, one may "hog" most of the current, could this be so?
    Frank
  3. harrymann
    Sep 3, 2013
    5
    You might consider changing your load cell brand. I think this is the fastest way to diagnose the situation. If this instance happens again, then it's not the load cell. It may be that the connection was not stable and unfit for use.
