OK, instead of connecting the clamp diodes to ground and Vdd, construct a pair of "clamp supplies" for the purpose: get a cheap, dual opamp and configure the two sections as unity-gain buffers; one buffer's input connects to a voltage divider set to give you +0.45V, and the other buffer's input connects to a voltage divider set for (Vdd - 0.45V). Now connect the clamp diodes to the outputs of the opamps, instead of ground and Vdd. (NOTE: you'll need to pick an opamp whose output short-circuit current is greater than the instrumentation amplifier's output short-circuit current, so when the instrumentation amp and the clamp disagree on what the output voltage should be, the clamp always wins.)...but that arrangement will only clip voltage higher than Vdd (or lower than 0V) by the diode's forward voltage, which in a typical schottky diode is about 450mv. In my case I'd like to clip the voltage at exactly Vdd and 0V, respectively, if possible. I'm all eyes and ears if you have a better idea.
Imhotep wasn't evil, he was just corrupt. Darned fine architect, though...To answer your question, I found that circuit in the last pages of the attached file... the relics of which where found being firmly grasped by the still-juicy, but thoroughly mummified remains (if that were possible) of the evil priest Imhotep.
