LNK306 output question
Status
Not open for further replies.
liel
Joined Jan 19, 2017
hey all
i am using LNK306. the datasheet reads its current output could reach 360mA as the top.
i was wondering that:
12V and 120mA were given in my circuit picture which i will upload, how could i increase the output to 5V 300mA ? I am familiar with the voltage adjustment, just wanted to know that if i down the voltage from 12V to 5V, will the output current increase? or should i make some change of any other part to increase the current? (Hope i have made my point clear)
more than thankful.
hp1729
Joined Nov 23, 2015
2,304
hey all
more than thankful.
I'm no engineer but it looks to me like if you change that 13K resistor to about 4,300 or 4,700 it should bring the output voltage down to about 5 V. How much current depends on which LNK30x chip you have.
With the 13K (and the 2K) it puts the feedback pin to about 1.6 V. So if you bring that 13K down to 4,500 it should set the output to 5 V. But then I'm no engineer.
DickCappels
Joined Aug 21, 2008
10,171
Yes, it works like that. Most likely when going to a lower output voltage efficiency will drop a little.
To what use do you plan to put this?
eetech00
Joined Jun 8, 2013
3,949
Hi
R2 = 2000, 1%, 0.25w
Vfb = 1.65
Ifb = 49uA
Vout = 5.00
Imin = 0.003A (min load current, use 0.005A for margin)
R1=(Vout-Vfb)/((Vfb/R2)+Ifb) = 3833
Rpl = Vout/Imin = 1000
Rplwatts = Vout*Imin = 0.02500
R1 = Choose 3.83k, 1%, 0.25w
Rpl = Choose 1k, 1%, 0.25w
L1 = 470uH, Rdc=2.0 ohm max, 450ma min
D1 = BYV26C
So...In your schematic, replace R1 with 3.83k, R4 with 1k, L1 with 470uH, D1 with BYV26C
LNK306 should work ok...
DickCappels
Joined Aug 21, 2008
10,171
Sorry but this fallsl under the heading of Transformerless Power Supplies, discussion of which are prohibited under the User Agreement. To wit:
Restricted topics. The following topics are regularly raised however are considered "off-topic" at all times and will result in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Any kind of jammers (ie - Phone jammers)
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    If You come across a thread or post discussing any of the above topics please report the thread so We can close, and if necessary remove, the offending thread/posts.
Status
